Back on the ground
Discussion in 'General Maverick/Comet' started by Will, Dec 26, 2007.
  1. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    Car is finally back on all four wheels. After doing the mustang2 swap there is a buttload of room in the engine bay now. I went ahead and put the 2inch drop spindles on after I already cut the springs...I'll be getting some different springs later. I've got a crapload more work ahead of me but it feels good to get this far.
    I have to thank Cleaver for all of his help.
  2. 71gold
    is it just me or is that header on backwards :huh:
    even at that it takes a lot of room to do that...:thumbs2:
    the writeup to follow...:yup:
    frank
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    if he is running a turblow.....it has to be backwards for the cooler thing a ma bob. :D
  4. Jamie Miles
    Cool... what crossmember did you use? Looks like stock Ford suspension parts. I keep thinking more and more about doing a Mustang II front on my car. Will never be running a big block, but I can think of a couple of modern V6's I would love to run that are physically damn near as big as a big block. :) I have a complete 3.0 Duratec V6 from my mom's Lincoln LS in my shed that just needs the bottom end gone through to solve a knock it had.
  5. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Hey Will. Lookin' good! All that room must be sweet. The Bullitts look good on there. (y)
  6. stmanser
    Davenport, Iowa
    doesnt really look like a butt load of room between the exhaust mainifold and the shock tower... maybe this is a bad picture angle to see the "extra room"
  7. Will
    Will I
    Waco
    stock crossmember, I used fox mustang mounting so I can bolt in anything from a 2.3t to a 460. It will get a turdblow i mean turbo
  8. DeJacks
    DeJacks Member
    Lemoore, CA
    1970 Ford Maverick
    Nice! Also looking forward to the write up:thumbs2:
  9. bmcdaniel
    That's the easy way to make the steering shaft fit. :D
  10. don graham
    that car is going to go real fast in reverse.:rofl: i like the wheels. they look good with the discs behind them.:)
  11. Mavaholic
    Looks good!!
  12. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Will,I just did 2 Must II fronts,my own Mav. and a customers,I am just starting to figure out steering shaft out of stock columun to rack with Borgenson joints and double D shaft,could you exsplain what you did on the column side,save me a bunch of time ,Thanks Jack
  13. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    I wouldn't change springs, it looks reeaaaalllllllyyy good the way it sits. IMO!:D
  14. Will
    Will I
    Waco
    Hey Jack, first off I wanted to use a rag joint since I'll be driving on the street 95% of the time. I used a factory fox mustang rag joint, all I ended up doing was trimming a tab off and cutting the 3/4 shaft down some and drill the bolt holes on the column slightly bigger. After that bolted up I got some 3/4 shaft and 2 universals, cut to length and tada!
