axle splines
Discussion in 'Technical' started by seth, Mar 29, 2013.
  1. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    I have An early 4 lug 8 inch rear and I was wondering if the spline count is the same as the later 5 lug 8 inch axles. I was thinking about switching the third member from the 4 lug rear to the 5 lug. Basically I want to know if they are compatible.:hmmm:
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    all the factory 8" rears use 28 spline axles.. whether they be open or trac loc.
  3. Acornridgeman
    Wisconsin
    Correct ........ :)
    The problem with an easy swap is the bearing size ..... this thread will help explain.
    http://www.maverick.to/mmb/showthread.php?t=20444
    :tiphat:
  4. Mavman72
    Center sections will swap from a 4 to 5 lug no problem...Axles will not due to bearing size.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    hmmm?.. the few that I've swapped on early Mustangs must be different then?
    Well.. luckily you guys chimed in to fill in the blanks and steer him in the right direction here then. Learn something new everyday. (y)
    EDIT: on the rethink.. makes perfect sense and I must have used the same axles and just swapped the pumpkins out, I guess.
  6. rthomas771
    Early Mustang have tapered tubes...Maverick doesn't
  7. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
  8. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Auburn better then the tru loc??
  9. Mavman72
    Either one would be a good choice at that price but...You will have to step up to 31 spline axles (Not a bad thing) If you plan to put ALOT of torque through them.
  10. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Ya i have to get new 31 spline axles. I been wanting to do this for along time just haven't wanted to put out that kinda money but I'm thinking about doing it in a month or so.
