Automatic Trans Fluid
Discussion in 'Technical' started by 691/2MAV, Nov 18, 2003.
  1. 691/2MAV
    691/2MAV Member
    Colorado Springs
    1969 1/2 Maverick
    Can you run the Dextron 3 in the C4 from 1976 or does it have to be type F?
  2. Mavaholic
    I was told by B&M to run type F for firmer shifts. Dextron III is the recommended type.
  3. don graham
    i don,t know what year they changed, but hughes transmissions in phoenix told me to use castrol type f. that,s all they use in all there trannys.:)
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I tried using Dexron III in my Spoiler,, shifted too loose. Put type F in it and now works like it should.
    Dan
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Everyone I have talked to about tranny fluid recommend using the type F............it stands for "fast".......I think :p
  6. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    I had a problem with downshifting on one of the Mavs. I changed the fluid with new type F and cleaned the screen. It corrected the problem. It is usually better to use what the vehicle originally called for.
  7. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    I have ran my C4 with dextron III before because thats all I had and it was realy close to being 2 quarts low. That has happend more than once and never had any problems with it but I changed the the tranny fluid with in the month, I`m sure there is still a quart or two of dextron III still hanging around in there though. It still ran just fine when my mother parked it and she got a newer better car to drive wich just so happends to be a big PITA to work on :mad:
  8. comet dad
    comet dad Member
    Longview, Texas
    1974 Mercury Comet
    what year did ford start rec. dexron?? I thought type F was up through80 or so ??? dunno ..... but the 74 says type F so......Robert
  9. Lightning
    Lightning Member
    Saskatchewan ,Canada
    1971 comet GT
    I was always under the impression that the type F had a different friction co - efficient . At one time ford was using different material on their friction disks and stated in their service manuals the type F spec . Nowadays I think all the jobbers ( and ford ) are using the same material . So dextron can be used in rebuilt transmissions .
    The rub is that ford did change their spec sometime in the 80s . If you dont know the history of a car or transmission it is hard to know which fluid to use .
    I always use type F to stay on the safe side if I dont know for sure .
  10. comet dad
    comet dad Member
    Longview, Texas
    1974 Mercury Comet
    ooooohhh
    so......if all rebuilts use dexron then that explains the WALL OF DEXRON vs the cubbyhole of type F at the parts house ....... learn sumthin' ever day ....... Robert:D
  11. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    As mentioned above, I had heard that Type F is known to give you a firmer shift.
  12. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    i would recommend type-f ....it is true that it is a firmer shift,besides if your tranny is original i dont recommend changing fluids now. running dextron in a tranny that has had type-f could cuase alot of slippage. just like switching from oil to synthetic without cleaning out the oil....they just dont mix. about the same quality as water and oil.....and something else to help you decide which to use....my brother-in-law run type-f in his turbo 350 for his top dragster which runs 6.7's at 200 mph in the quarter and his is a chevyman....you decide lol
  13. fordman
    fordman Member
    lufkin texas
    1972 maverick
    if you run low at the track on type f most of the GM boys use it GM guys i race with use it helps them to keep up with the fords:D
  14. courier11sec
    courier11sec Member
    Tucson, AZ
    Trans fluid.
    Dexron III is designed to pruduce soft smooth shifts that won't frighten old ladies on their way to the tea room.
    Type F produces firmer crisper shifts which is why it's not used in anything OEM any more.
  15. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    well thats somewhat true ...the real reason is that ford trannys had powerbands in them and it was used to keep them from slipping.............chevrolet doesnt have bands so there was no need for them............most racers use type-f becuase it helps hold their pumps together
