Autokrafter's Tubular A-Arm setup
Discussion in 'Technical' started by scooper77515, Apr 3, 2005.
  1. scooper77515
    Does the Autokrafter's Tubular A-Arm Coilover setup allow me to open up my engine compartment (ie. lose the shock towers and put in a big-block)? Are these similar to the Mustang II setup?
    If so, how difficult is installation of the kit? Has anyone used these, and are they good quality? There is also a slightly cheaper version, not coilover. How is that one? Part numbers are *RCM3 for coilover and *RCM2. Would I be better off finding a Mustang II?
    Any Help? :huh:
  2. bmcdaniel
  3. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Both kits are based on Must.2 . Only differance in the two is one uses coil spring and a shock the other uses a coil-over shock. I would go with the coil-over due to the adjustablity.How difficult to install all depends on your ability and tools ,of course.
