Auto Trans hole size...
Discussion in 'General Maverick/Comet' started by A_Bartle, Jan 24, 2007.
  1. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    I'm going to use a car hauler, so I'll be taking the drive shaft off the Maverick. I called around to try and find a universal transmission tailshaft plug, but no luck. I did call a transmission shop and he said that he has some extra plugs leftover (must be shipping plugs?) but needed to know the right dimension of the hole. Does anyone know the answer to that?
    Thanks!
    Art
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    If only you'd asked last night I could have gotten my caliper and checked mine. If you don't have an answer by tonight, PM me a reminder to check it.
  3. Acornridgeman
    Wisconsin
    I have used an old driveshaft slip yoke. Just put it in and use a bungy to keep it from sliding back out while going down the road. This is what I use when pulling engine/tranny so the fluid doesn't pour out while lifting the engine out.
  4. spork1o1
    spork1o1 Member
    Michigan
    last time I put one on a toedolly I just unhooked the drive shaft (after putting the car on the dolly) and used a meatle coat hanger to tie the drive shaft up and out of the way.
  5. Acornridgeman
    Wisconsin
    So that's why I see driveshafts laying along the road sometimes ..... always wondered how the car kept going without it ..... :clap:
  6. Dave B
    The National Parts Depot catalog says:
    " 1.44" OD, 67-73 C-4, 4sMT small input, and 1.7" OD 65-66 C-4, C-6, FMX, 4sMT big input"
    Theres a NPD just outside Detroit, and they have 1-day shipping in Michigan.
  7. Jerryfow2
    Jerryfow2 Member
    Milltown IN
    1972 Grabber/1972 Sprint/1976 Stallion
    I used a couple of plastic ziplocks zip tied over the tail shaft area once. Worked pretty well. But then I wasn't going very far either.
    Jerryfow2
