i have been looking at auto krafters for the v8 frame mounts and i only found these are they the rite ones? http://www.autokrafters.com/v4/go.g...products&show_product_id=732402&product=26341
NO. those won't work for a 302 or 351w. Your best bet is to advertise in the parts wanted section of this board. Someone will have the correct frame mounts,Usually about 150.oo which includes belly bar.Good luck
If you don't find a used set. Check with www.critesrestoration.com they should have a set of frame brackets for $99.
The 3 bolt frame mount pattern for the Mavericks and Comets has a different configuration than the Falcons, Comets, Mustangs from the 60's. They need to eliminate the Maverick and Comet from the 70's from the description.
