aode vs 4r70w case size
Discussion in 'Transmissions' started by bomrat, Aug 26, 2011.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    hi, is the 4r70w a larger case in any way from the aod?
    thanks
  2. 71gold
    your title said...aode...:huh:
  3. PaulS
    no..... depending on the model and years being compared.
  4. 71gold
    that sounds more like a...maybe...:yup:
  5. PaulS
    there are minor differences between models.
    The length of the output shafts and extension housing. There are differences in the outside diameter of the yokes. The other dimensions are the same.
    so depending on the year and model you may have some differences but the distance from the bellhousing mounting surface to the rear mount will be the same.
