AOD Questions
Discussion in 'Transmissions' started by 1973Maverick357, Dec 8, 2009.
  1. 1973Maverick357
    Cookeville TN
    I know this has probably been asked a million times. But i know where a AOD out of a 94 mustang is. What all goes into the making of it fit. Driveshaft? Transmission Crossmember? And What are the advantages of the AODE?
  2. mean_maverick
    '94 had AODE and requires it's own controller/computer to operate the OD. not worth the hassle
  3. 1973Maverick357
    Cookeville TN
    Oh alright thanks for the help.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Id almost say if a guy had the budget for it. That would be the way to go. But, the internals will fit in a aod for a hugh strength and durability upgrade.
  5. PaulS
    If you can get the 94 AODE cheap enough and find a core AOD you can swap the parts from the AODE into the AOD case and use the AOD valve body.
  6. justin has a 74
    kentucky
    You need a different transmission bar thing, 71 gold makes them.
