Anyone running a Hurst 4 speed shifter. Please look
Discussion in 'General Maverick/Comet' started by DaMadman, May 11, 2009.
  1. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    Which install kit did you use?
    I think this is the shifter and install kit I need but I am only pretty sure not 100% sure
    Hurst 2917634
    Competition Plus 4 Speed Shifter with Installation Kit
    Part #s 3913180 (Shifter) & 3737637(Install Kit)
    Anyone else use this Hurst shifter for a 4 speed and use this installation kit with it?
  2. spork1o1
    spork1o1 Member
    Michigan
    Post a pic of the side of your trans. Need to know the location of the shifter mounting on the tail shaft.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Go to the Hurst website and pick the tranny profile that matches yours.
    There are roughly 5 tailshaft profiles for a Toploader 4 speed. Hurst has a number that they assign to each profile tailshaft and mounting points... 431, 432, 433, etc... You find the number they have assigned to your tailshaft, then cross reference it with your shifter part number, and that will give you an install kit part number.
  4. DaMadman
    Southern MD
    Trans is out of a 67 mustang
    Tailshaft has these numbers/letters
  5. DaMadman
    Southern MD
    Thanks I went to hurst website and I am pretty sure I found the info I needed in their shifter catalog. Looks like by Hurst Standard I have a Ford T & C 433 4 speed toploader. and it looks like the shifter and install kit I was looking at will work.
    Transmission is on the way and the shifter is on the way so I guess I will know for sure int he next few weeks to a month when I have it all put together and installed int he 73 Grabber...
    Can't wait to get that old worn out O/D trans and ragged old shifter out and get the new stuff in so I can really shift some gears the way they were meant to be shifted... The fun way without having to force the shifter in gear and without havign to hold pressure on the shifter to keep it in 3rd LOL
