Any nice prepackaged rear disc packages?
Discussion in 'Technical' started by wv72grabber, Mar 31, 2011.
  1. wv72grabber
    wv72grabber Member
    WV
    '72 Grabber
    I read the explorer rear disc install post in tech.
    Have searched and found several donors locally but they have either been made out of gold or had one side already scalped.
    Front 5 lug disc conversion is all but done, little paint and some TRE's, so i am turning my attention on the rear.
    Are there any prepackaged kits or conversions that you guys prefer/have experience with?
    When i swapped rear discs on my '85 bronco all i had to do was bolt on a plate and mount up some chevy front discs and the rear was done, got a brand new 8 lug rear disc setup for approx 300$ ...
    looks like the little Mav is gonna be double that?
    (it would be cheaper to use the dana 60 or 70 that i have laying behind the shop, narrow it, cheapo axles and voila, 8 lug disc brake rear Mav:rofl2:)
  2. mojo
    8 lug disc brake rear Mav - what wheel wud u possibly use w/ 8 lub axle???
  3. maverick75
    The lincoln/explorer brake swap is the cheap alternative. Have you tried a pull it yourself junkyard? Out here we get a complete read end with brakes for $150, other states usually have cheaper prices than out here..... If you have an 8" then you can use a brake kit for a small bearing 9". But they're not cheap, they start at around $600.
  4. baddad457
    If you've got a stock 8" rear, go look at the rear discs on the 92-up Crown Vics. If not mistaken, the backing plates bolt onto 8" rears and make a fairly easy & chear swap.
  5. maverick75
    Well, well. Speedwaymotors.com has a kit for $350! I found it googling.
  6. wv72grabber
    wv72grabber Member
    WV
    '72 Grabber
    that fits the old and new big bearings not mav 8" small ford
  7. injectedmav
    injectedmav Member
    Georgia
    That Explorer setup should still be available from Ford Racing new.
    It's also listed on the Speedwaymotors.com site for $389
  8. wv72grabber
    wv72grabber Member
    WV
    '72 Grabber
  9. 71gold
  10. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    I'm with Frank ... give them a call ... and let US know what they say :D
  11. FishnRace
    FishnRace Jamie
    '72 2dr 351
  12. wv72grabber
    wv72grabber Member
    WV
    '72 Grabber
    went ahead and ordered a set ...
    will post up results ...
    actually went to napa and priced all new disc parts for an explorer and the total came to 240$ ...
    so when you throw in locating an axle, pulling the used backing plates and then buying the Napa replacement parts it seems like money well spent for me ...
  13. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    Any updates?
  14. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    try scarebird on e-bay
  15. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I looked at Mustangsteve.com he sells a braket that fits the 8" and gives the model year for ford calipers and rotors that will fit or you can buy his.
