another one comes back...
Discussion in 'General Maverick/Comet' started by tim keck, Jan 9, 2010.
  1. tim keck
    sharps chapel,Tn
    I sold this '74 with the white '71 Grabber I got back a couple months ago. Now it's back again. While it looks like crap in the pics it's actually pretty straight & solid. It's a 200/auto(pulled from the '71 Grabber-this car's engine was locked up when I sold 'em). They drove it about 50 miles after the swap and it sat for a while. Now it won't do anything. When this weather lets up I'm gonna check the grounds, solenoid, and fusible link(and hope it's that simple and that no critters got up in the dash). During it's extended "vacation" it acquired a few extras; a new windshield seal, new carb, new wheel cylinders/brake shoes on the front and a trunk littered with some headlight bezels, wiring, etc.. With pretty good floors & quarters, this one could be a builder...:dancing:
  2. comrick317
    comrick317 Banned
    Mississauga, Ontario
    1976 Mercury Comet
    Hell it looks solid to me and very colourful and you can't beat the fact that you sent it out and got it back with new parts.(y)[​IMG]
  3. don graham
    Funny how these cars seem to go around in circles.:)
  4. bobtackett
    bobtackett Member
    chicago heights ill
    1971 mav 302 4bbl headers
    tim do you want a set of rear 1/4 caps.i've got a set from my car i just put a grabber rear spoiler on.just give me shipping and there yours.
  5. comrick317
    comrick317 Banned
    1976 Mercury Comet
    At least this Maverick didn't go to the bone yard.
  6. tim keck
    sharps chapel,Tn
    I've got a set on another car, plus I may do a small bumper conversion anyway. Thanks though.:)
  7. tim keck
    sharps chapel,Tn
    Well, I got it to start up, runs good and drove out the road & back. Let it sit & run for about 15-20 minutes in the yard(got some old gas in it, but still ran ok). Then I shut it off for about 30 minutes. Tried to start it back up and...nothing. Well,the idiot lights in the dash come on when you turn the key but nothing under the hood. No clicks, buzzing, nothing. I though maybe the neutral safety switch may be bad or the linkage was out of whack, but moving the shifter around does nothing for it. I'm thinking either the solenoid is bad or the starter is getting weak. Tried to jump it over on the solenoid with some pliers, it just sparked. Any thoughts?
  8. Mercurycruizers
    Venetia, PA
    Starter switch? I had that problem. It was a $17 part @ Shucks...
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Sounds like the starter bit the dust. Mine did that, had just started it, went dead, tried it again, nothing. Sparked at the solenoid like yours. Another starter fixed it!
  10. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    Heat soaked starter or a bad connection? :huh:
    -Scott H.
  11. bobtackett
    bobtackett Member
    chicago heights ill
    my 74 i had back in 79 was missing a couple teeth on the flywheel.i burned up 3 starters over a period of time and got the warrentee replacement on each one till the manager of the car shop got tired of seeing me and replacing them.i went to one more car shop and pulled the same stunt then finally put a new flywheel in the car.needless to say i got good at changing the starter on my maverick
