Aluminun Intake Gaskets
Discussion in 'Technical' started by rebelgt, Apr 30, 2007.
  1. rebelgt
    rebelgt Member
    Southeast Missouri
    1972 Comet GT
    Anyone have any luck running Edelbrock intake with stock FEL Pro gaskets. I didn't want to buy another set if these would work.
  2. don graham
    i use felpros on my edelbrock aluminum intake and aluminum heads. no problems here. i run a bead of permatex ultra blue around the water jackets. i also use ultra blue instead of the end gaskets, but you'll get a lot of opinions on that. there was a post last week about that.:)
  3. scooper77515
    I have used only Felpro. I have done the sealant only at the back and front, and I have used the little cork gaskets in the kit. I had a leak at the back once, didn't use a thick enough bead at the back. Other than that, in 6 or 8 swaps, no problems either way.
