Aluminum Head Damage...
Discussion in 'General Maverick/Comet' started by Maxx Levell, Jul 5, 2012.
  1. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Just got AFR heads back from machine shop. First trip out with the new combo this year, things went terribly wrong, and all exhaust valves ended up bent. I mic'd the clearance before ever firing the engine, and knew that I had enough piston to valve clearance.
    Upon delving deeper, I discovered that the camshaft sprocket dowel pin had sheared off, allowing the cam to rotate a bit...enough to apparently retard the cam enough to smack all of the exhaust valves! At least none broke, only kissed the pistons and bent enough to make a difference!
    After talking with folks, it sounds like the bolt holding the sprocket in the center probably loosened up some, allowing the pressure to be transferred to the pin. The pin is only an alignment dowel, and is not designed to keep the sprocket from turning.
    All in all...it cost me around $1400 for new valves, pushrods, gaskets, and heads repaired.... I went to EBN and bought a replacement pin for 58 Cents!!! OUCH!!!!!!!
    Anyway...the cam bolt now has RED loctite securing it, and I hope to get the engine installed back in tonight. Maybe this weekend will be a little better outing!
  2. darren
    Yep done that myself. Cost me a nice 302. Mine was much worse. Before the pin broke the cam walked back and the cam lobes hit the lifter next door,took chunks out of the lifters which found there way into my oil pump and stopped it dead. You may want to have a peak at your cam and lifters if its still apart. Hopefully your cam didnt walk back like mine did.
  3. blugene
    Duuude that stinks! I am trying to understand how it could shear.. The only load to the cam is the valve springs isn't it? Otherwise it would just turn ..? :hmmm:
  4. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Cam and lifters looked fine. Solid Roller cam and lifters .614 lift IN/ .621 Ex. I'm gonna guess that with the bolt not holding pressure against the sprocket...the "slack" in the timing chain was enough to allow them to hit. I'm running dome pistons, with about 13:1 compression, so there wasn't a whole lot of clearance to begin with. I checked it again yesterday as I was putting it back to gether and had .121 on the exhausts...which is enough...but it ain't much lol. Intakes had more...but they don't necessarily need as much.
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Bummer, Guess that is the reason some double pin their camshafts.
  6. Rick
    Rick G8I operations
    Ocala, Florida
    Man that sucks, I red loctite everything on my car.
  7. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Good luck this weekend, would love to hear how you do Tom.
  8. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Thanks Ward...I suspect it will run much better without the valves hitting the pistons :thumbs2: ...that's been my experience in the past anyway :biglaugh:
  9. darren
    ITs pretty common Gene. Seen many Hemis do it. Lots of load on that little pin on accell and decel if the bolt is loose.
  10. darren
    Glad your cam is OK.(y)
  11. Fro
    Fro Member
    Joplin Mo.
    19691/2 maverick 1971 maverick
    Be careful I've machined several lately for double pins. And honestly I don't think the bolt has much to do with it. The last one I did had already been machined for a 3/8 bolt and was using an ARP stud with a hardened ground washer and it wasn't loose when it sheared. It's double pinned now with 2 unbreako brand dowels. This motors springs are 700 psi open pressure and .730 lift.
  12. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Wow...that's not very encouraging lol. I'm planning on switching to a bigger cam over the winter, and will have it drilled for double pins...or can you order them like that new? Never checked...I've never had this happen...or even knew anyone that it happened to actually. Will definitely be in the back of my mind for a while though.
  13. Fro
    Fro Member
    Joplin Mo.
    Surely you can order them that way. I understand that all of the Pro 5.0 guys double pin but they are definitely the most extreme in the small block world. I don't know how extreme yours is. It may be fine. These engines I've been helping with are 650+ hp to the ground. No power adder.
  14. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Hope all goes well for you.
  15. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    Now this has got me thinking about if i used loctite or not.:hmmm:
