Alum Rad & Thermostat
Discussion in 'Technical' started by mojo, Apr 26, 2010.
  1. mojo
    I have a new Champion radiator in my Comet and running a new 180 stat. I have a Jegs elec fan control 195on/170off. I was driving the car today in 50-55 degrees temps and runs 180 as long as Im moving. I wanted to see what idling temps I wud get idling abt 10-15mins and I got to 230 and seen enough- I shut it down. I have a 16in fan mounted on the radiator.
    I think I may have to go to a 160 stat. The fan control specifies a 180 stat. I have to make a change B4 the wx gets hot - for sure.
    Does anyone else have this issue?
  2. justin has a 74
    kentucky
    air pocket, pull the radiator cap of and let it run for a half an hour.
  3. Bryant
    the fan is not enough. get a tauras fan out of the salvage yard. they have a shoud that fits over the whole rad core and will cool the the radiator when your standing still.
  4. PaulS
    Changing the thermostat will not make it run cooler at an idle - like they said above - you need more fan to move more air through the radiator.
  5. mojo
    OK. I thought abt the stat comment after I made the thread and realized it wud'nt make any difference.
    Fan Shroud? Im going to look into the Tarus fan or fab a shroud frm sheet metal I hve laying arnd. As I take a gud look at the pix I attached here I see I have a lot of core not having air pulled through by the fan.
    Thanks guy's for the advice.
