Alternator question
Discussion in 'Technical' started by mrcomet, Jan 9, 2012.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Hello,
    I've got a sound coming from the alternator. Changed the belt and it still does it on low idle or as I am slowing down. I'm thinking it's the bearing. Are the bearings easy to change?
    If I go with a new unit I want to go to a one wire hookup. But I have a wire spliced in now that goes to a voltage gauge inside the car. Is their an extra pin on a one wire unit I can hook the wire to and still feed the gauge.
    Thanks!
  2. mojo
    mojo "Everett"- Senior Citizen
    U can use any wire inside the car that,s activated when the ignition is on. I assume ur talking abt an aftermarket voltmeter?
    I have one wire 130 amp; that upgrade eliminated all the reg and wiring clutter.
  3. ptpdub
    ptpdub Member
    canada Sk.
    not hard to change the bearing but everything else in there has been used the same amount of time. get a full rebuild kit. do it all. not hard to do.
    1 wire alternator is what I did and I love it. easy, clean, and much less clutter.
  4. mojo
    I agree. If ur going to take it apart - may as well do it all .
