Alternator mounting bracket FYI
Discussion in 'Technical' started by jasonwthompson, May 27, 2016.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    So I finally upgraded to a Ford 3g 130 amp alternator and thought I would share something that probably most people know, but I did not. I was installing this on a 72 Comet with a 302. The lower alternator bracket has a stamping of d0oe. My 75 Maverick 302 lower alternator bracket has a stamping of d3ae. The d0 bracket attaches to the lower ear of the alternator in the front. The d3 bracket attaches to the ear on the back. "So what", you say. With the d0 bracket the alternator bolted right in without any modification to the bracket or alternator case. The d3 bracket could not attach without some bracket and/or alternator case grinding.
    Here are a couple of pictures to illustrate.
    Bracket behind ear, similar to the d3
    Bracket in front, similar to the d0
    YellowStangDuan likes this.
  2. QuietStorm
    QuietStorm Member
    Houston Tx
    Ford Maverick 1975
    Hi, I'm trying to install my alternator on my ford maverick 1975 & I was wondering if you can help guide me through. Let me know what bolts & brackets Im missing.
  3. 71gold
    :Welcome:...:Handshake:
  4. QuietStorm
    QuietStorm Member
    Houston Tx
    Ford Maverick 1975
    Thank you!
  5. QuietStorm
    QuietStorm Member
    Houston Tx
    Ford Maverick 1975
    Here is what I'm working with. Just need some help with the parts and installation.
  6. bmcdaniel
    I installed my bracket on the front with a little grinding since I put a 3/8-16 Helicoil in the alternator so I don't have to fool around with a nut behind the bracket.
  7. QuietStorm
    QuietStorm Member
    Houston Tx
    Ford Maverick 1975
  8. bmcdaniel
    Don't know. On mine I had to make a longer spacer but I'm running a Crown Vic serpentine setup.
