Alternator light staying on
Discussion in 'Technical' started by Hairy W Bush, Oct 24, 2015.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    I have a brand new alternator and a battery that's not that old. I just had them retested at the parts store and they are great. I made sure my voltage regulator connection is tight as well as the alternator connections so I'm not sure what the problem is. I started the car about 10 times and it doesn't seem to be slowing down any. Kinda worrying me as I don't want to be stranded anywhere.
  2. 71gold
    did you have them checked on the car?
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    no i brought them to the store.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Did you replace the regulator? Back in the day when I was in auto parts they wouldn't warranty an externally regulated alternator if the regulator wasn't replaced. You should also check your fuses, I had a similar issue and the fuse for my instruments was bad. Replaced it and all was well.
  5. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I don't believe that's it as I am getting 12.2v to the alternator. I replaced the regulator when I got the car. The most I've driven it was about 145 miles last year. My instrument lights don't work but it's not the fuse.
