Alternator and Ignition switch
Discussion in 'Technical' started by Krax, Aug 24, 2010.
  1. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    Does anybody know what kind of alternator my 73 Maverick 250 CI is? 2 pulley or 1, and how tricky are installing ignition switches? Could I do it with no experience? And can somebody look at the autozone list of both items and tell me which ones would fit?
  2. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    1 or 2 pulley is easy, how many belts are on the alt? That's your answer. Ign switch isn't that hard, it is on the top of the column. Why do you think you need a switch?
  3. PaulS
    If it is stock you have a one pulley alternator. The "key" part of the switch is at the top of the column but the electrical part (rod-opperated) is at the bottom of the column.
  4. YellowStangDuan
    Arlington, Texas
    71 Grabber
    My 250 had a two pulley alt, but it was factory air, that's why you need to count the belts on the alt.
  5. simple man
    simple man Member
    Bunnell,Florida
    You can change the alt pulley to the one you need. When you get your alt just have them swap it from your old one. The ignition switch,the actual electrical part,takes some contortionist moves to do,but it's pretty simple. The "key" part itself is more difficult. You have to remove the steering wheel with a "puller". You can usually rent this tool from the parts store very reasonably.:)
