Added H-pipe. Just moved the drone to different RPMs.
Discussion in 'Technical' started by scooper77515, Mar 27, 2011.
  1. scooper77515
    I have been complaining since I put in my Flowmaster Super44s that the car has a horrible drone at cruising speed (55-65 mph) that at times i thought was u-joints going out, out of balance driveshaft, transmission mounts and tailshaft housing. Well after replacing all of those, I fabricated and installed an H-pipe to try to eliminate the drone.
    After welding and cutting to make one in the best available location ( see thread http://mmb.maverick.to/showthread.php?t=76511&page=1) I finally got out to test drive it, and now it still drones, but I just moved the speed of the drone down to 40-50 mph. It starts out with that slow cycling vibration at 40, then it speeds up the cycle until 50, and just after 50 the noise just disappears and it is smooth sailing at cruising speed. Haven't gone above 70 yet, but then I seldom cruise at that speed.
    So at this point, I will either sell the Super44s and go with glasspacks, extend the pipes out from under the car, or just learn to get used to it. Or maybe figure out something else that may work...
  2. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    That's why I won't put flowmasters on anything I own.
  3. scooper77515
    I probably wouldn't do it again. I was "young" when I put them on.
    What would you put on in the future, instead of Flows?
  4. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I exited mine outside the body and it cured the drone 100%.
    Then I replaced the whole thing with sidepipes and it is surprisingly quiet.
  5. mercgt73
    I think with a little group brain power and a few calculators we can get your drone down. Unfortunately, it also boils down to you experimenting, and sometimes that is not fun the fourth or fifth time. Especially when its your driver.
  6. PAINTANK
    1973 Comet 2 dr
    Patriot fixes this.
    Seriously though, exit the exhaust past the rockers instead of straight down.
    That was the miracle that stopped the teeth jarring drone I had with Flowmaster 40s at 35-45mph.
  7. scooper77515
    Paintank, I agree, I had NO DRONE when I had the patriot side pipes. Only picked it up when I put the Flows on dumping under the car.
    The only time I heard the sidepipes was when I was on a bridge and heard the sound echoing back at me.
    I loved those sidepipes, except they drug on EVERYTHING!!!
  8. cyclonewill
    cyclonewill Member
    I run full tailpipes, with Hooker aerochambers on the 89 5.0 & the Ranchero. The 'stang has cheap ($35) Summit race mufflers, none of them drone.
  9. PAINTANK
    1973 Comet 2 dr
    When my Flow 40s dumped down it droned. When I 45ed them and they stuck out past the rockers the drone magically disappeared at all speeds. Still sounded mean, just not deafening.
  10. Craig Selvey
    You need tail-pipes.
  11. scooper77515
    Does this mean exiting out the side of the car in front of the wheels?
    I have Cal-Tracs, which makes side-exits difficult, even though that is what I like best...old pic...
  12. PaulS
    Pick a spot - out the sides or out the back - either will work.
  13. Streamliner
    Streamliner Member
    This is my side exiting setup with no mufflers....Had the same set-up on a '66 Stang with a 347 and it was the best sounding car i've ever owned....You have to get them out from underneath the car
  14. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    That's weird. I have 2.5 inch pipe and 2 chamber Flows with an H-pipe. Dumps right before the axle and it sounds really aggressive but no drone. What did I do right? :huh:
    Steamliner: Did that X-pipe quiet your car a little? I want to reduce the volume just a little and was thinking about a set up like that with mufflers. It looks awesome. :clap:
  15. Streamliner
    Streamliner Member
    On my Maverick it hasn't been run yet but on other cars i've had with it it mellows the sound out and is slightly higher pitched
