Accident damage might be worse than I thought
Discussion in 'Technical' started by aquilaprime, Oct 19, 2005.
  1. aquilaprime
    aquilaprime Member
    Abilene, Texas
    1972 Grabber Wannabe
    I started taking the front end apart, so could start making an inventory/priority list for rebuilding the Mav. I pulled the radiator away from the fan and tried to crank the car. I got a terrible grinding noise. It was getting late, so I stopped for the night.
    I am wondering (hoping) that it's the waterpump, rather than the starter or engine bearing(!)
    -A.P. Out, for now
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Check to see if the pulley got bent and is making contact with the water pump body.
  3. Ford_Motorheads
    Ford_Motorheads Ford Addict
    Phoenix, AZ
    1961 Falcon, 1967 Ranchero, 1969 Gran Torino GT, 1974 Ranchero GT 1976 Mustang Stallion, 1977 Mustang coupe, 1978 Mach 1, and 2 1978 Cobras
    Hopefully it isn't anything seriously wrong.
  4. NICK DOMINICK
    Burke, Virginia
    If you have an automatic transmission check the lines that go to the radiator. They could be hitting the crank pully.
  5. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Remove all the belts, then start the engine, this for sure will rule out the water pump,alternator,power steering pump or AC pump.
