ac vacuum help
Discussion in 'General Maverick/Comet' started by jerrymal, May 29, 2011.
  1. jerrymal
    jerrymal jerry
    Brownsville tx
    1973 maverick
    I have a 73 maverick with factory ac , the problem is that the control switch doesn't work . The only switch that work is the one to turn on ac/fan. In other words the fan won't turn by itself the compressor has to turn on and the other two control switches won't work, the one for defrost and a/c fresh/max. My question is might it have to do with the vacuum hoses. I notice two hose from firewall are connected, one to tran and the other to motor. But next to them I have 3 smaller hose plug(about 1/4 in thick) ,my question is are these related to the control switch, where should they be connected. They are plug with a little screw. Help
  2. Craig Selvey
    So when you turn on the fan...does the air flow only come out the defrost vent at the top of the dash?
  3. rthomas771
  4. Stingrayiii
    Stingrayiii Member
    Las Vegas
    1973 Ford Maverick 302/auto
    Same thing Craig said! I had the problem of air flow only coming out of the defrost vent. And I had to buy a vacuum canister. (I guess that is what it is called, looks like a tuna can to me.) And that fixed my issue.
  5. jerrymal
    jerrymal jerry
    Brownsville tx
    1973 maverick
    My canister produces vacuum so I think I need the ac control switch cause if i put vacuum direct the vents work. If anybody has one let me know. Thanks
