ac control
Discussion in 'Technical' started by togetic2002, Aug 26, 2007.
  1. togetic2002
    togetic2002 Member
    Reno NV
    72 sprint(major reconsruction),92 5.0 ho t-bird
    :huh:im doing me headlights in the other post and when i was taking the cluster out i noticed a lil disk laying on it w/rubber on 1 side and a notch on one side
    i see where it goes and it controls a switch but what does this switch do for my vents or heater?
    is this why its always stuck on defrost?
    and how do i put it back on?:huh:
  2. 19BlacK77
    19BlacK77 Member
    Is the thing your talking about look like this?
    If so that is the part that controls which vents are on and when the a/c is kicked on and off.
  3. Mavaholic
    Its pretty common for that switch to fall apart. You got to find another one if you want your blower to blow anywhere other than defrost. The heating system in all the factory ac cars is controlled by vacuum doors rather than mechanical. If you can find that switch in a 70, they are made of metal rather than plastic.
