AC Compressor Oil question
Discussion in 'Technical' started by lngroller, Jul 31, 2005.
  1. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    My 74 Comet with factory installed air is getting a few new parts. In the upgrade I will be cleaning out the Compressor and hoses to get rid of the old oil. My question is how much oil do I put back in? I can't seem to find the oil capacity or recommended charge (of Oil) for the York compressor.
    Thanks
    Dave
  2. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    I usually put 4oz. in them, 6oz. in bigger systems, 4 oz. will work for a York style or Sanden compressor.
  3. Thack
    Thack vision advicator
    Moreno Valley Ca
    The 70 ford manual I have says 11 oz for the Tecumseh and 10 oz for the york. It also says 1 7/8 lbs of r12. That is for a completely cean system it does seam a little high I just did my 77 f-100 and I only used 7 oz but I am using a newer rotory style pump.
  4. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    Thanks, There isn't a high pressure relief valve in these compressors is there?
  5. 74merc
    74merc computer nerd
    1974 Comet
    don't think so. I've been through my system, nothing I haven't identified yet...
  6. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    Thanks everyone for all your replies.
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If you have access to a MOTOR manual they have a section on A/C that details on making a dipstick to check the oil level in a compressor before you charge the system. Mine is a late 70s early 80s edition, its out in the carport right now or I would look it up for you..........its 10:45pm and everybodys asleep but me!:hmmm: Better half gets ill when I wake her up! :D
  8. abadmav
    abadmav New Member
    Sara.Fl.
    72 & 70 mavericks
    a/c
    Are you going to use R12 or R134A?R12 is expensive and hard to get,R134A is at any parts store.Does it have a expansion valve or orifice tube?
  9. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    I'm going to use Freeze 12 with ester oil. It's a compatible R12 alternative.
