about transmission
Discussion in 'Parts Interchange' started by maverickdad, Sep 28, 2003.
  1. maverickdad
    maverickdad Member
    Martinsville Indiana
    1974 maverick
    I still have question about trans. What is the difference between a 3- speed auto with automatic overdrive and a 3- speed with overdrive?
  2. rx7351w
    rx7351w Member
    knoxville, tn
    74 2 door Maverick
    I would say they are the same. It is just different way to say the same thing.
    If I was going to get a 4 speed automatic I would get one from a 300 I6 in a truck. An AOD is a good choice if it will bolt up (I dont know the bolt pattern of the 300 I6) If you can get one from a mark 8 or supercoupe it would be alittle stronger or you could get one from a mustang. With the AOD you have to make sure the TV cable is adjusted correctly or it will burn up in less than 10 miles but it is not computer controled like the AODE.
    Chad
  3. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    the 300 I6 has the same bolt pattern as a 250 I6 and SB fords
  4. maverickdad
    maverickdad Member
    1974 maverick
    about trans
    Thanks guys for the input. That cleared that up for me.
