a little upset
Discussion in 'General Maverick/Comet' started by bartikus, Oct 5, 2004.
  1. bartikus
    bartikus Member
    salt lake city, ut
    so i found out a few days ago that the tranny i just put in my car was not a 4 speed toploader but a 3. when i was at the junk yard the shifter and all the linkages were really sloppy and it felt like a 4 speed. it's ok because i ended up with every thing i needed to do an automatic to manual swap and it runs great now. had to modify the z-bar and weld the little stud that goes on the shifter back in place (that's the reson it felt like a 4 speed). but i'm just glad i got rid of that automatic. two auto trannys in 4 months isn't good. and it's not my fault they died. the one was going out when i purchased the comet and the other one was used and had who nows how many miles on it.
  2. mavman
    mavman Member
    Arkansas
    yes...if it's a street car, the manual trans is the ONLY way to go. Much more fun, even if it is "only" a 3 speed. That opens up the door to more options later on when the budget allows. 4 speed should go right in, as well as a T5 with a couple simple mods.
  3. bartikus
    bartikus Member
    salt lake city, ut
    indeed, thats the plan.
  4. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    My jeep "only" has a three speed but it sure is fun :D .
  5. BIGbully
    BIGbully Maverick Maniac
    Omaha, Ne
    Look at the bright side. It is a four speed. 3 forward and 1 reverse.(y)
    Now if I can only figure out if my washer fluid is half full or half empty.:D
  6. fordracin
    fordracin New Member
    Logansport, Indiana
    An easy way to tell a 4-speed toploader from a 3-speed is to look at how many shifter shafts the trans has. Three shafts is a 4-speed, two shafts is a 3-speed. Maybe this will help someone...
