A fix for floppy AC vents.
Discussion in 'Technical' started by facelessnumber, Aug 1, 2011.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    This might be old news or common knowledge, maybe everybody does this and I was the last one to figure it out, but just in case I can help somebody out, I'll share an idea I had today...
    The round AC vents in a package tray dash are supposed to have a felt strip around them to hold their position and keep them from flopping around. Mine did when I first got them, briefly, but the adhesive had broken down and very soon the felt had fallen out. I just wedged the vents where I wanted them and left them alone for a long time, but decided to try and fix them today.
    The solution: Velcro. Bought a roll of black adhesive backed velcro tape, cut it to about 3/8" width, and was able to slip the fuzzy side of it in there where the old felt strip was. Works great!
  2. kyle1972
    kyle1972 Member
    Modesto California
    1972 4 door Maverick 250 I6
    thanks for the idea, just found some i can use today
  3. 71gold
    for lack of a better way of putting it...I took my balls apart, installed new self-sticking felt and then reassembled them.
    your way sounds like the same thing but different...:thumbs2:
  4. mojo
    I need to do my dash ac vents. I will try the velcro on them. I replaced the round package tray vents w/ modern style ones. This thread was right on time.:)
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Good idea. thanks.
  6. 71gold
    got a pic.??? :yup:
  7. mojo
  8. 71gold
  9. jmgford
    jmgford Member
    Iowa
    and less painful! :eek:
  10. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I have been thinking about ordering some of those from NAP for a while now. Thanks for the pics. I like the Velcro idea, I think I'll try it on my vents. I still need the adapters to hook up the hoses though.. They were left off the vents when I bought the tray.
  11. mojo
    Along w/ installing something to create resistance in the dash vent/louver outlets, I also believe Im losing quite-a-bit of air around where the old fiber plenum meets the register. Im getting cold air out but I think it cud be improved.
    I noticed when re-assembling the dash plenum it was deformed, I suppose frm years of being subject to temp changes. Although, I had installed some rubber strips along the perimeter I had to remove it to get the register to fit up in the dash. I think something thinner and more flexible, might work.
    When I got everything workin this spring I just wanted to be able to have some heat and AC by summer to make the MCCI RU -- I did that so Im happy.. :bananamanIt works but I think it cud be more efficient.
    I will look into some kind of upgrade to sealing it agn once the wx cools down -- mid 90's is not wx I relish workin on cars or anything else for that matter.
    I am wondering if anyone has made any mod's in this area. If so, what method or means was used and was there appreciable improvment????
  12. facelessnumber
    Memphis, TN
    '71 Grabber
    I used duct tape and I'm not ashamed to admit it! It's a duct. I did at least use black tape though...
  13. mojo
    I took ur suggestion and put some Velcro in the vents, as stated, the stuff works well. Thanks for ur idea. Quick, easy, simple expensive fix. :)
