A Carbureted Supercharger
Discussion in 'Technical' started by Bioinfomatic, Sep 5, 2007.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
  2. RabidCustoms
    yes a centrifical supercharger like the one you posted will work, you will just need a few different misc parts, the one shown is for an injected engine. youll need a pressure box for your carb, and your carb will need some mods as well.
    I'm sure a few of the "more in tune" underhood blower guys will chime in with what I left out.
  3. newtoford
    newtoford Member
    New Castle Delaware
    theres actually a guy that brings a supercharged 302 maverick around to some of the local cruises. its a really nice car but i doubt that that 302 under it is anywhere close to stock.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Paxton makes a system for use with a carb. This is the setup that Terry Hahn has on his car.
    www.paxtonauto.com
  5. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    whats a recommended compression ratio to stay under for a supercharger like this?
  6. RabidCustoms
    most stay around 8:1 to 8.5:1 anymore
  7. PaulS
    The lower pressure you start with the more you can add. stay under 8.5:1 and 8:1 is almost ideal unless you are set up to deliver the higher pressures that a 6 or 7:1 ratio would need to perform correctly.
