88 5.0 roller motor
Discussion in 'Technical' started by GRABBER/74, Mar 22, 2007.
  1. GRABBER/74
    GRABBER/74 Member
    high ridge missouri
    74 maverick grabber
    hey guys
    i have a question i've fond an 88 5.0 roller motor an trans complete for $200.00
    a friend of mine does demo cars an he said he's going to pull the motor an trans out runs great 70000 miles my question is can i pull the injection off
    and make it carbrated for my 74 grabber it has a 250 six c4 thanks grabber/74:dance: :drive:
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Yes you can pull the injection and swap to a carb and intake.
  3. baddad457
    You'll need a steel geared distributor for it as well if it's a roller cam.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    It's a little more complicated than just carb and intake.
    Block the air pump holes.
    Switch to mechanical fuel pump - you need eccentric and timing chain cover and oil slinger if you can find one.
    The 88 engine has a 50oz imbalance flywheel so make sure the flywheel and harmonic balancer are both 50oz.
    88 is roller cam so a hardened or brass gear on the dizzy is a must.
  5. GRABBER/74
    GRABBER/74 Member
    high ridge missouri
    74 maverick grabber
    88 5.0
    im getting the whole motor trans and drive shaft for 200.00 delivered
    to my house will pull the motor here so what i don't need i'll set aside
    thanks for the input grabber/74
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I believe you will need to swap to a front sump oil pan as well as the change in pump and pickup.
    Dan
  7. dmhines
    Cumming, GA
    Oh yeah ... I knew there was something else .... (y)
  8. baddad457
    Don't forget to plug the dipstick hole in the side of the block. If your car has a column shifter, you'll need to fab a bracket to support the shifter linkage too, the 5.0 blcok doesn't have the hole for this that the earlier ones did.
