80s to 70s engine conv
Discussion in 'General Maverick/Comet' started by x72COMETx, Dec 6, 2012.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    i have a 85 ford 302 block and i want to make it a 70s carburated so i can put it in my comet and i need to no if theres anything different between the years thanks
  2. Mavman72
    Unless you use the serpentine belt set up off the 85...You will need a standard rotation water pump and front cover. As well as a front sump oil pan and pickup.
    You will also need a 50 oz flex plate or fly wheel depending on trans choice...
  3. scooper77515
    I have an 85 block in mine. You can check out my webpage and see what all I had to do to make it work. Link below...where it says Della website
    Convert it to roller cam and really wake that thing up!
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    You should read the tech article http://mmb.maverick.to/showthread.php?t=36034 There are a lot of details to consider like fuel pump, dip stick, clutch linkage or auto column shift linkage, distributor gear, harmonic balancer, flywheel or flexplate, and oil pan/pickup.
  5. x72COMETx
    x72COMETx Member
    Vallejo CA
    the engine came almost complete the only thing missin was the oil pan and intake
  6. scooper77515
    ...which is good, because it most likely had the wrong oil pan, and a fuel injected intake. You would have had to scrap them both and replace.
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    i have a 2 bll intake and a new oil pan butthere for a 70s block would they work
  8. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    They'll fit but why would you want to put a 2 bbl on it. If you have to swap it over you might as well go with a 4 bbl.
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    i got the 2bll for free and i already had the carb
  10. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    good reason!
  11. scooper77515
    Use the pan, buy a used 4 bbl intake. There is no reason to jump up to a 5.0 and use a 2 bbl intake.
    You can get a decent intake for $100 or less.
    And for a couple hundred more, or less (if you can barter and trade for parts, I got mine free!) upgrade to roller cam, roller rockers, and roller everything!
  12. x72COMETx
    x72COMETx Member
    Vallejo CA
    what kind of distributer can i use does it have to be an 85 or can it be a 70s
  13. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Why would you want to go from electronic to points?
  14. scooper77515
    Distributor gear needs to match the cam. So if you use the newer cam, use the newer distributor gear (and distributor, if you want).
    I use an old points style distributor, with Pertronix installed, and newer distributor gear to match my newer cam. I just didn't want all the extra wire you get with an electronic distributor.
  15. Krazy Comet
    Is it a HO engine or a std output???
    The '85 HO was 1st to use a roller cam and requires a steel gear on the dist(that's '85 5-speed ONLY, automatics used a flat tappet iron cam with CFI), the '85 Dist could be used from a 5-speed as it's a Duraspark....
    Just in case it isn't a '85, all prior had flat tappet cam and ALL '86-up passenger cars had a roller cam(that's right HO or std output), trucks didn't get the roller cam till the early '90s... Std output & trucks use same firing order as the earlier 289/302(15426378), the HO has 351 firing order(13726548)...
