8 inch rearend fixer upper
Discussion in 'Parts Interchange' started by stmanser, Jan 16, 2005.
  1. stmanser
    Davenport, Iowa
    i bought an 8 inch rear end today from a junkyard. it is from a 79 granada.:bananaman
    it looks like it is in good shape...the axles rotate and the yoke spins....no sticking at all..and it feels nice and smooth...for 2.79 gears...they gotta go
    Now i want to fix it up...get it all ready
    to take the member out, do i need to remove the axles first...?
    there is a weird looking hunk of metal on the lower front of the rear end that isnt on my maverick's rear end...looks like a mount...but on the bottom..??
    not sure what it is....
    any ideas?
  2. rayzorsharp
    Yes, the axles have to come out. There are 4 bolts on each axle. There is an access hole in the end of each axle. You can turn the axle and line it up with each bolt. Take a deep 9/16th socket on an extension and they are very easy to remove. Sometimes the axle will pop out pretty easy, sometimes they need a little help such as a slide hammer or similar tool. After the axles are slid out a few inches the center housing will come out with no problems. Be aware that this unit is very heavy in case you are doing it laying on the ground.
  3. 71gold
    jerry,
    are you implying that his "rear end" might be twisted? :huh: is this something that could have happened driving through the "disco" era? :huh: :bouncy: :biglaugh:
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I found one in a '76 Mercury Monarch for $70. I'm thinking about getting it so I can push the rear wheels out 1/2" on each side...
  5. stmanser
    Davenport, Iowa
    79 granada wider?
    is the 79 granada rear end wider than the 71 maverick's rear end?
    also this note is for razor...i tried to get in touch with the company about the lower front spoiler....and nobody has responded
    can you give me the name again..maybe i got the wrong name in google search
    thanks
  6. Old Guy
    Old Guy Member
    Just for clarification, are you sure it is an 8in? Have seen those vibration dampers on the 7.5 and 8.8 but never on an 8in. Does it have the drop out center or have a cover on the back? Just wondering about some things I may have to learn about.
  7. stmanser
    Davenport, Iowa
    it has the front loader style.....and i just checked it again....and it is a 10 inch drum and 5x4.5" lug pattern
    i dont think its a 8.8 but then again...there is only this on the tag
    WDW-AF 9AA
    2 79 8 551A
    it has 10 inch drums and 5 lug 4.5 inch spacing
    and it has the vibration dampner.....it is a front loader and has 3 bolts on top and bottom and 2 bolts on each side of the member
    please let me know what i have....the junkyard said it was a 28 spline 8 inch rear end
  8. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    Yes it is an 8". When you get a chance measure the length of it vs your Maverick rear, I'd like to hear the results. My Lincoln rear is wider but I think that is because of the rotors. I'm not sure if the Granada drum rear is wider or not.
  9. stmanser
    Davenport, Iowa
    and one more question.... will my master cylinder be able to handle the new 10 inch drums on the new rea end...my rear end has 9 inch drums currently,...
    will the master cylinder handle that?
    im not sure if this is going to help anyone..
    the 79 granada rear end is 49.75 inches from inside drum to inside drum
    the rear end on the maverick is over 50 inches inside drum to inside drum
    i am sure that is because the drums are thicker on the 79 rear end
    now the drums on the maverick are much smalled and i am sure that the rear end will fit...but over all lenght wont be easy since i will need to remove the wheels...and i dont have the time to do that right now..
  10. T.L.
    T.L. Banned
    Southern Colorado
    Doesn't make sense that the Granada rear would be narrower than the Maverick. The front track of a Granada is wider than a Maverick (the frame is wider) so I would think that the rear would be wider also...:confused:
  11. rayzorsharp
    Mas Racing does not have a website...you'll have to call them.
    MAS RACING PRODUCTS
    2288 UNIVERSITY AVE, W
    SAINT PAUL, MN 55114
    Phone: 651-644-6811
  12. stmanser
    Davenport, Iowa
    thanks....rayzor...
    i will measure it again.. but i am sure that it was 49.75.
    will the master cylinder be ok now that the drums are bigger in back?
  13. T.L.
    T.L. Banned
    Southern Colorado
    Granadas use the same master cylinder as the late model Mavericks...
  14. stmanser
    Davenport, Iowa
    mine isnt a late model.... its a 71
    so i guess i can add a new master cylinder to the parts upgrade list now that its a 302
    i want power brakes....but i dont want the hassle of tracking everything down and running accesories off the engine
  15. T.L.
    T.L. Banned
    Southern Colorado
    Your master cylinder will probably work fine...
