8.5" rearend conversion
Discussion in 'Technical' started by Camtemple, Dec 17, 2004.
  1. Camtemple
    Camtemple Member
    BC Canada
    Maverick
    I was just wondering what all it took to do a 8"- 8.5" 5.0 mustang rear end conversion. I'm thinking about getting a used 8.5" posi rearend out of a mustang as a cheaper slightly stronger alternitive to getting a posi for my 8" factory maverick rearend. I'm also thinking of doing susspension work while I'm putting the new rear-end in, I know a master susspension guy so there wouldn't be a problem putting in some funky suspension work.
    My wheels are 15x7 with +2mm offset. Right now with the stock rearend I have 1/4 inch spacers in so that my tires don't rub on the leaf springs around corners, so if the mustang rearend is longer by a bit it'll work out well.
    thanks for the help
  2. Fearmont80
    Fearmont80 Member
    Burbank,IL
    Doing that swap right now....look elsewhere/do a search for my topic on it.By the way,Mustangs used an 8.8" rear,GM used the 8.5
  3. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    Consider using an 8.8 out of a leaf sprung Explorer.
