77 maverick efi
Discussion in 'Technical' started by gwil81, May 5, 2009.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    i have a 77 with a brake boost. will the 90 5.0 intake clear the booster. does anyone have pic's
  2. ChadS
    ChadS MacGyver Smoker
    Indiana
    70 Maverick 5.0 EFI
    If the TB is on the passenger side, it should clear. Only thing I saw when I did mine was the shock tower brace had to be redone to fit the plentumn correctly without either reaising it up 1.5 inches or dropping it 2 inches to clear the passenger side brace. I used a typical SD upper plentum off a 88-90 5.0 with a 90 degree throttle body instead of the angled setup, like seen on an explorer,, etc etc. Chad
