74 rear end question
Discussion in 'Technical' started by leps66, Mar 29, 2012.
  1. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    Okay I bought what is suppose to be a 74 maverick rear end.. What I wanted to know is how do you know if it is a 74 rear or 75 up rear.... I noticed that the drums and brakes are different for these years. Thanks for any info.
    Thanks for all the info. I should of just ask what is the differences in the rear drum brakes from 74/75 to 76? Thanks.. I just want to make sure what year my rear end is before i start buying brakes and lines. Thanks guys I do appreciate all the information.
  2. Dave B
    Measure the size of the hole in the brake drum, or the stub of the axle. I can go and measure one in my 73, and one in my 74, they are different sizes.
  3. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
    I'm thinking 74-75 drums are the same 10" drums. If you are looking to order brake shoes, measure their width to be sure, probably 1 3/4" wide or possibly 2 1/2"
  4. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    The rear ends are pretty much the same has for the brake system if its a 5 lug. I have notice for a 72 that the axles are different. The center portion of the axle that goes into the center rim was smaller than other years.
  5. injectedmav
    injectedmav Member
    Georgia
    disc brake cars use the larger centering hub. discs were an option in 74 but I don't know for sure if the drum brake cars had the larger centering hub. 75 and up were all disc brake sized centering hubs. I believe that is the difference in the drums.
  6. mike75mav
    mike75mav Member
    Bremerton, WA
    He's talking about the rear end not the front end.
  7. injectedmav
    injectedmav Member
    Georgia
    I understand that. The front having disc was a guarantee that the rear was originally equipped with larger centering hubs. What I am unsure of is if the 74 with drum brakes had the smaller hub centers.
  8. mike75mav
    mike75mav Member
    Bremerton, WA
    The centering hubs are the same for the drum brakes. I have a 75 with drum and the center hubs are the larger ones.
  9. FordCountry180
    Parkesburg, PA
    The center hole in the drums for 74-75 is about 2 3/4" or slightly more. The earlier drums were just a little bit smaller, around 2 1/2".
  10. baddad457
    But the wheels will have larger center holes all the way around, that was his point. The disc hubs had a larger outer diameter than the drum hubs, thus the wheel centers will be larger on the rearend as well.
