74 250 runs rough in gear
Discussion in 'Technical' started by waynel, Feb 19, 2004.
  1. waynel
    waynel Member
    NY
    1974 maverick
    It runs fine in park and nutral but once you put it in gear it runs rough like it wants to stall
  2. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    It may seem to run fine in park, that is because there is no load on the engine. Not sure what your question is? Once a load is put on the engine and it runs rough, there could be alot of things causing it to do that. Carb. adjustment, timing. vaccuum leak, grounded spark plugs/wires, choke stuck, etc...............
  3. waynel
    waynel Member
    NY
    1974 maverick
    it has all new plugs wires cap and rotor but i put a carb off of a 300 on it and it ran a little better someone said it might be the tourc converter could that be the case
  4. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    It could be the torque converter but I realy don`t think so . Did you put new points in it ?
  5. waynel
    waynel Member
    NY
    1974 maverick
    no I didn't try that but i will thanks
  6. elliot
    elliot Member
    Boubon MO
    and the condencer or how ever the heck you spell it
  7. waynel
    waynel Member
    NY
    1974 maverick
    yeah i'de change those together just like on my bike
  8. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    coil going bad ?
  9. HeLMeT 76x2
    HeLMeT 76x2 Two 76 Fords...!!!
    Vancouver, wa
    1 1976 ford 4-door maverick. 1 1976 ford econoline 100.
    that happened to me cuz my valve seals were going bad and my plugs fouled sometimes
  10. waynel
    waynel Member
    NY
    1974 maverick
    i'll have to check all that I apreciate all the ideas thanks
  11. MaverickGrabber
    Cardington, ohio
    had a coil do that to me would run fine in park could even rev it up as soon as a load was put on it dead had just put a new B&M torqe converter in it thought it was bad
  12. Earl Branham
    Lugoff, SC
    Try pinching off all the vacuum lines one at a time, till you find one that does not change the way it runs. Also, check the vacuum advance can on the dist. Put a piece of vac. hose on it and pull a vacuum, with the cap off, and see if it moves the advance in the distributer. If not, the diaphram is bad. This will make your car run at a retarted timing set once it is underway. Let us know,
    Earl
  13. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    This probably isnt the problem but this happend to me a week ago, just from vibrations i guess one of the nuts on my engine mount bolts fell of, and the engine would shake like hell when ever i put into gear, and almost die.
  14. waynel
    waynel Member
    NY
    1974 maverick
    i'm gonna have to try all that hopefuly i figure it out but it wont be till the snow is gone thanks for the advice
