72 comet light switch
Discussion in 'Technical' started by x72COMETx, Feb 18, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    my light switch went out on my 72 comet and so i bought one from o Reilly and it was different so i need to no were is a good place to buy a new switch from thanks
  2. rthomas771
    What part number was on the box?
  3. x72COMETx
    x72COMETx Member
    Vallejo CA
    Brand was bwd Part number is s149p
  4. mercgt73
  5. Krazy Comet
    What's different??? From what I can see the S149P is physically same as switch in my Comet...
    BTW original Ford number on my switch is D2AB-11654-A1A...
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    the rod that pulls out of the switch to turn the lights on stuck out to far
  7. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  8. Krazy Comet
    The switch at Dearborn Classic is same as one I have from a '69 Torino and has the D3 number(so it's a replacement)... That switch is also exactly like the orig from my Comet(both of those are defective)... What I have in the Comet now is a C5 number(1965 origin, prob orig from a Torino) that also was same physically, works & fit perfectly...
    There is a bracket inside the dash that keeps the switch spaced back, so the shaft doesn't extend to far outward... Sooo if that's in place, the lock pin on back side is in same position & switch spacing for the dimmer section is same, only thing I could see wrong would be length of shaft...
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    ok finally have the dash apart to get the number off my switch D2DB-11654-AIB
  10. Krazy Comet
    So how did you know the replacement didn't fit until you got the orig one out???
  11. x72COMETx
    x72COMETx Member
    Vallejo CA
    i had the original one out before when i first bought the replacement one and installed it and noticed the rod stuck out to far so i put the old one back in and left it alone since it semi worked,
  12. x72COMETx
    x72COMETx Member
    Vallejo CA
    now that i have the dash apart again i would like to replace the light switch since the illumination lights dont work anymore
