71 Maverick Grabber Gas Tank Wont Take Gas
Discussion in 'New Members Forum' started by JacobLambert, Oct 17, 2009.
  1. JacobLambert
    JacobLambert New Member
    Conway, AR
    1971 Ford Maverick Grabber
    I have a 71 maverick grabber and when i go to the gas station to put gas in it will take about a fourth of a gallon then spew gas out of the hole you put the gas nozzle into. If anyone has had this problem and knows how to fix it please help.
  2. mav1970
    :Welcome: to the forum from Northeast Pennsylvania
    I've had tanks that acted the same as yours. I used to have to keep turning the nozzle around and slowing the flow until I could get the gas to go down the tube without closing off it's ability to vent.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    yea, try turning the nozzle upside down and push it in all the way, should work for ya
  4. sierra grabber
    sierra grabber Certifiable
    northern nevada
    welcome aboard
    also dont open the valve all the way, i usually do about half on it since the new high speed feed systems are designed for new cars with good pressure relief. even if your vapor tube is perfect it wont let out enough pressure for most of the new pumps...
  5. Bob55
    Bob55 Member
    Marysville, WA
    My work truck is the same way, '08 F450....gotta hold the nozzle a certain way and only trigger about half, otherwise it's an all day affair to refuel.
  6. GrabberJoe
    GrabberJoe Member
    Brooklyn, Michigan
    1974 Maverick Grabber
    :Welcome: from Michigan! I have owned Mavericks since 1974. Slow the flow of gas has always worked for me. This was difficult in 1974 after waiting in line for 45 minutes!!:cry:
  7. mav1970
    You made me think about those around the block gas lines during that so called shortage. That is wenn the gas prices started going up and I sold my 1965 Buick Skylark Gran Sport 401 because I was damned if i was going to pay 44 cents a gallon for high test. :cry:
  8. Rando76
    Rando76 Member
    Claremore, OK
    :Welcome:
    I changed my filler tube on my '73 to a filler tube from a '76. Any of the newer unleaded Mavericks will work. It has a smaller hole with a flap that helps with the backsplash. I haven't had a problem since I did it.
  9. rthomas771
    I did this also and it did the trick.:yup:
  10. rayspaceboy
    rayspaceboy Member
    Denton, TX
    I also use the upside down method. I had to do this with my 77 Ford Clubwagon too.
  11. MikeG747
    MikeG747 Member
    Arkansas
    Welcome to the board neighbor! (y) Let me know if you need any help. :tiphat:
