68 mustang no key
Discussion in 'Other Automotive Tech & Talk' started by randytatum, Jan 10, 2014.
  1. randytatum
    randytatum Member
    mccomb, ms
    i bought a mustang 2 days ago crunk it up runs well needs some body work... i had the keys in my hand before i got back in the truck but now now i cant find them... i called around here and spoke to some locksmiths and they where 100.00 to 150.00 which is something i dont wanna do.. any suggestions?
    i heard people drilling in the center of the lock but i have never did that before
  2. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    I've changed the whole ignition cylinder on my other cars before... Was cheaper than having it re-keyed
  3. randytatum
    randytatum Member
    mccomb, ms
    how did u get the cylinder out? thats my problem if i had the key it wouldnt be a problem
  4. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Haven't done it in a maverick.... But in a Nissan Stanza and an Olds Cutlass Cierra, you pull the steering wheel using a steering wheel puller (on loan from your local parts store) and then unscrew whatever is holding it in and screw the new one in. (y)
  5. mercgt73
    Is your ignition cylinder in the dash or column?
  6. randytatum
    randytatum Member
    mccomb, ms
    its on the dash
  7. mercgt73
    Try any other Ford double sided keys you have first, they may work on that worn cylinder. Wiggle and jiggle, you may get lucky. If it turns, then use a paperclip to release the cylinder and remove it the regular way.
    If you cannot get it to rotate, get a small regular screwdriver and a pick (or a hairpin, or something else to rake the tumblers). It may take you some time, but it is the cheapest option. Once you can get it to turn, the cylinder can come right out.
  8. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Yes, do what he says. I had to do that to the Subaru I just bought. Used an old Nissan key from my downstairs neighbor and just wiggled and forced it until it turned. Don't force it so hard you bend or snap the key, but while wiggling they key also give some love taps at the cylinder and you should be able to bump it over. They haven't made a car ignition (with normal keys) that can't be bump turned yet.
  9. Craig Selvey
    Pull the lock cylinder out of the door. TAKE IT TO THE LOCKSMITH. Ask them to make you a key for that lock. The last time I did this it cost my $10....yes ten bucks.
