68 F100 rearend???
Discussion in 'Technical' started by Jap901, Jun 15, 2005.
  1. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    My cozin has a 68 F100 parts truck he said I can have the rear end out of it if I can use it.
    I know it will have to be cut down but i have been doing some reading on them older rearends and some of them are DANA rearends with like 23 splin axles don't think that be any better than the 8in but if its a 9in i can just have them axle cut down to? because if i am right i beleave i read some where, some time in the 70s the axle where taperd and those could not be cut down.
    Also would it be any cheaper to have the axles cut down or just by new ones?
    Thanks Jim
  2. Jamie Miles
    Alto, GA
    I've had a few
    If it's an original '68 F100, it will definately have a 9 inch. F250's of that era had Dana 60's.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    F100 should have a 9". The heavier trucks ran the Dana which will have a removable rear cover.
    Personally I would just buy a set of aftermarket axles rather than respline an old set.
  4. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Thanks Guys I will do some more checking to make sure I realy hope it is a 9".
    It is a orginal 68 f100 long wheel base truck with a 360 and 3 speed on the column.
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    My dad has a factory shortbed F100 that came with a 360, 3 on the column.
    It came with a 9 in. 3.25 non-positive. That rear is quite a bit wider than
    your Maverick Comet. It should also be a 28 spline axle.
    Seth
