65-66 mustang springs?
Discussion in 'Technical' started by FoMoCo73, Apr 20, 2005.
  1. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    '73 302 parts car 1969 1/2 351w/tko-500 in progress
    so let me get this straight..
    65-66 stang springs work on a mav.
    but 67 and up dont?
    i see that Mustangs Plus sells a coil spring, upper insulator, and spring perch combo for mustangs for $110
    id like to order it....but i need to know if it will work for sure.
    im redoing all the front suspension....i have everything else....all i need now is the spring and perch/bushing.....(i know....shoulda bought a kit with everything) :oops:
    ohwell....
  2. Maverick Man
    California
    its the other way around the 67-73 will work.. i had the same question when i was doing mine.
    $110 is a good price.. i bought mine from mustangs unlimited and it was way more! but i just got a flyer from mustangs plus today and they have the same $110 set up for $99 now! if you didn't get it the flyer use the advertising tracking code for 0505RD
  3. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    thanks!
    i need to get a bigger sway bar too.....i obviously cant use one from a 67-73 stang cuz its wider....
    anyone know what to use?
  4. Maverick Man
    California
    you can use that 67 / 68 .. you just need to relocate where the bar mounts a bit forward.. i have a 67 / 68 on my car now but just to lazy to relocate it. the endlinks are not right up and down they edge to the outside a bit.
    addco makes one for the maverick but its 7/8 i think and the mustang ones are 1 inch
  5. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    what size is the sway bar?
  6. Maverick Man
    California
    what do you mean what size? :confused:
  7. RabidCustoms
    Addco will make you any size bars you need
  8. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    I have a '65-'66 1 1/8th inch, the width was the same, but from end link to the front was longer on a Mustang, mine lean backwards a little, still plan on relocating the mounts, havent had the chance yet.
  9. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    sorry.....i meant what size do you have on yours?
  10. Maverick Man
    California
    1 incher
  11. bmcdaniel
    65 & 66 Mustang springs are the same part number as a Mav, later Mustang springs are different. But the rest of the Mav suspension parts; control arms, ball joints, saddles, etc. are the same as 67 - 73 Mustang.
  12. Burlap1
    Burlap1 fat lazy truckdriver
    Urbana ny-wine country finger lakes wines are best
    1983 f-150 4wd,1971 cougar parts car,1973 maverick parts car,1970 maverick formerly a gramma's grocery getter,1984 f-250 460 powered,1976 f-350 u-haul,and some chevy's
    could a person use struts from a lincoln or a newer stang on the front of a mav?i have access to some but wasn't sure if they would fit
  13. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    what do the 67-73 mustang springs do to the maverick as far as right height? thanks
  14. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    hmmmmmmmm.......:hmmm:
    maverickman says.....67-73 stang springs fit a mav...
    bmcdaniel says.........65-66 stang springs fit a mav...
    i just ordered 67-73 springs, perches, and a 1 1/8" sway bar.
    hope it works...
  15. FredH
    FredH Member
    Seminole, FL
    69.5 Maverick
    I don't know about the 67-73 springs but I have 1966 Mustang 6 cylinder springs on mine and they fit perfectly in the saddles.
