5-speed question
Discussion in 'Other Automotive Tech & Talk' started by Bum's_Steer, Apr 19, 2011.
  1. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Will a Borg Warner T-5 from a 4.6 Mustang work behind a 302 with a change of bellhousing, or is the input shaft different?
    A friend of mine got a deal on a wrecked Mustang and offered to give me the T-5.....can't beat that price, thought I might try to stuff it in my 69.5 Grabber clone
  2. injectedmav
    injectedmav Member
    Georgia
    The T5 wasn't mounted behind a 4.6l that I know of. That would be a T45 or a Tremec 3650, both of which are designed with integral bell housings. I don't think it will work without a lot of work.
  3. Acornridgeman
    Wisconsin
    Doesn't sound very promissing. This is copied from a Mustangs forum ....... :16suspect
    Borg Warner T-45 transmissions were only used behind 4.6L single and dual over head Mustangs from 1996 to 1999. Tremec, in 2000, replaced the T-45 with the 3650 which is very similar in design. The T-45's design is very much like the T-56 six speed transmissions. In fact the T-45 and T-56 share many of the same parts. It has single rail gear selector and carbon lined steel synchro rings making it a smooth shifting transmission at high rpm's. The gears are larger and stronger then a T-5 and about the same as a Tremec 3550 in size. The T-45 is the first transmission in the B/W -Tremec lineup with a built-in bell housing so it can not be exchanged. This limits the T-45 to 4.6L mod motors as the bolt pattern is different than a Windsor push rod motors.
    T-45 from 1996-98 GT are different than the Cobra Mustangs. The transmission mount point is moved further back for the Cobras and as well as a 8 tooth drive speedometer gear. Cobras T-45 are equipped with a 7 tooth speedo gear. In 1999 all T-45's were changed to the Cobra specs. Why this was not done earlier is not understood.
  4. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Here's a pic.......definately looks like bellhousing can be seperated
    Now I'm :hmmm:
    Maybe I should go back to looking for a Toploader or T-10
  5. 302-72-mav
    302-72-mav Member
    sactown CA
    get it and sell it to get a t5 :yup:
  6. Bryant
    that sure looks like a t5 to me. give more pics. i would see if that bell housing bolts up to a 302.
  7. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    That looks pretty similar to my T5. Came from behind a 3.8 V6. Its internally the same as the ones behind 8s and the bellhousing bolts right up, only issue is the starter and its quickly fixed.
  8. Joe Dirt
    That's a t5 in your pics it will bolt up fine to your 302
  9. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Therein lay my confusion, he initially told me it was out of a 97 GT, which would have had the 4.6.....turns out it was a V-6 model.
    So, it's relegated to the back of his garage til I can find the time (and gas money) to make the trip to get it
  10. injectedmav
    injectedmav Member
    Georgia
    the 3.8l T5 is the same dimensionally, but I think you have the longer input shaft and different bell housing. bell housing isn't a problem if you use the earlier one (85-93) but you'll have to change the input shaft too and I had issues with the headers on the later one (94-95 V8, 94-04 V6) and the input shaft is longer on the later one meaning you have to match the bell housing to the input shaft or change it like I did to run the earlier bell housing. shorty headers may not have the same issues I did with the long tube 6901's
  11. Jamie Miles
    '94-'95 V8 T5's and '94-'04 V6 T5's had the deeper bell housing and longer input shaft.
