5 lug rear
Discussion in 'Technical' started by Jamie Miles, Mar 22, 2006.
  1. Jamie Miles
    Alto, GA
    I've had a few
    I am about to swap in a 5 lug rear in my '72. Would it be a good idea to replace the U Bolts? If so, where do I get them? How tight should they be torqued? Don't want to lose my rearend while driving down the interstate or something. :tiphat:
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I'd replace them. They're inexpensive enough. Just get them "tight". The nut goes so far past the end of the bolt threads that there is no way it can back itself all the way off and cause the rearend to fall off. Sorry I don't have an exact Lb.-Ft. torque number for you, but "tight" should be sufficent...
  3. Craig Selvey
    Defintely replace the U-bolts.
  4. Jamie Miles
    Alto, GA
    I've had a few
    Ok. Anyone know where I can get them?
  5. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    Landrum Spring co. in Atlanta,ga or Big Mo in Lithia Springs, ga.
  6. stmanser
    Davenport, Iowa
    any rear end place or an auto parts store... make sure you cut off the excess bolt after putting the nut on...make suer you leave 1/2" to 1" past the nut... and then i like to grab a screw driver and a hammer and smash the threads a bit, so that if the nut does loosen.. it wont vibrate off
  7. T.L.
    T.L. Banned
    Southern Colorado
    I got my new U-bolts from ESPO, and since they're the same size as the originals, no cutting was necessary. Just bolt 'em on and go....
  8. 71gold
    we have a place in town that makes the bolts...:yup: ...frank...:bouncy:
  9. T.L.
    T.L. Banned
    Southern Colorado
    We have one here too, but the guy is expensive and I was ordering bushings from ESPO anyway, so I got the U-bolts from them while I was at it...
  10. Jamie Miles
    Alto, GA
    I've had a few
    Probably be easiest for me to just get them at the auto parts store. Didn't realize they would have things like U bolts there.
  11. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    U Bolts
    Auto Parts Store Wont Be Close So Go Where Others Got Them Saves You Alot Of Time I Have Returned A Lot That Was Not Close
  12. Acornridgeman
    Wisconsin
    Anyone in a Fleet Farm state (upper midwest) - they have a great selection of them.
    Warning: thread stealing!
    I have a great u-bolt story. Back in my 4x4'n days, we had a guy in our group that pulled apart the complete underside of his F250 high boy to clean it all up and paint it. Since money was always tight, he reused all the u-bolts. But he thought that to beef up the truck some down there, he would harden up the u-bolts. He case hardened them with the oxy-acetelene torch and quenched them in a pan of old drain oil. They looked beautiful, all shiny and black. They also shattered like glass the next time he went 4 wheeling. That was wild!
  13. Jamie Miles
    Alto, GA
    I've had a few
    What do you mean they won't be close?
  14. 71gold
    take an old one with you...frank...:bouncy:
