5.0 EFI alternator bracket modification.
Discussion in 'Technical' started by 71Mavrk, Jul 2, 2014.
  1. 71Mavrk
    71Mavrk Member
    Nevada
    Engine: 1989 Mustang 5.0
    I’m setting my accessory brackets in place. I just remembered that the dipstick tube will not clear the stock alternator bracket and a hole needs to be drilled through the bracket.
    For those that have done this conversion, can you send me or post a picture of where you had to drill the hole. I don’t want to butcher this thing up doing trial and error.
    Thanks,
    Micah
  2. scooper77515
    I just bent my tube a bit, and flipped the tube holder so that the dipstick came up just near the alternator bracket bolt.
    Can't find a picture.
    Currently changed my setup again, and don't have a dipstick at all. Otherwise I would shoot a pic for you.
  3. Bryant
    i did the same as scooper when ive done this conversion.
  4. 71Mavrk
    71Mavrk Member
    Nevada
    Thanks guys.
    I was putting the brackets on and remembered this was an issue. The dip stick tube was at the powder coater. So, I had no way to check. If I drilled the bracket and screwed it up, I wanted to get it back to the powder coater to get done with the tube.
    I ended up finding a couple of photos. After seeing your posts. I went and got the tube and bent it a little. I think it will fit. I did not install yet.
    I'm having a tough time reinstalling the brackets. They were off the engine when I got them and I didn't get all the hardware. I think I have it figured out now.
    Micah
