4 wheel disc brake problem
Discussion in 'Technical' started by bayareamav2, Sep 4, 2010.
  1. bayareamav2
    bayareamav2 Member
    san francisco bay area
    71 and 73 maverick
    so i went ahead and installed a new dual res. (front/back) master cylinder booster combo and did the explorer rear disc conversion. not 100% sure i dont have a small leak somewhere but my problem is i still have a soft pedal. i push the brake pedal and the lights dont light up until a few inches from bottoming out.
    my variables are this...
    ----im still using the original drum/drum distribution block (i have one for a disc brake car)
    ---- i also threw in a summit adjustable prop valve to regulate fluid to the rear and not sure if i ever really needed it
    ---maybe i need a power brake pedal??
    any ideas before i start tearing everything apart, reflaring these old lines and finding the right fittings can be a p.i.t.a so any suggestions would be appreciated.
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    did you bench bleed the master cylinder?
  3. jojosmaverick
    jojosmaverick Member
    Thomasville, NC
    1970 in the works 5.0
    Go with Mashori on this bench bleeding a master a must do. U can even do it in car if you have some spare fittings and tubing lying a round, also check the push rod length, that is also extremely important in the operation and pedal feel.
  4. Mavman72
    Power brakes have a different pedal ratio than manual brakes...Locat a power brk pedal or do a lttle searching through the forum.There is a thread that discussed the ratio and the difference in the pedals...Good luck!!!
