4 speeds...
Discussion in 'General Maverick/Comet' started by outlawjose, Jun 14, 2010.
  1. outlawjose
    outlawjose Member
    USA
    2 dr Maverick
    anyone still run a 4 speed trans? i've seen alot of cars on here with t-5 conversions. not alot with 4 speeds. got a 4 speed in mine, but exact specs are highly confidential. trying to keep my mouth shut on this one. i also wanted to say, that i really like the mavs on the forum.
  2. bmcdaniel
    Let me guess, you used a Chevy Saginaw or Muncie 4 speed? :) Before I put in the T5 I ran a TopLoader 4 speed for a lot of years, but the 3.89 rear gears made highway cruising tough. The T5s OD cured that.
  3. tody
    tody Member
    cologne, germany
    i plan on putting a wide ratio 4 speed toploader in mine. 2.75 rear gears should make it very usable on the german highways with pretty high speeds.
  4. outlawjose
    outlawjose Member
    USA
    2 dr Maverick
    Actually, I have a Toploader. Had alot of bad luck with t-5's over the years. My problem has been too much horsepower and abuse. BTW, Sag's and Muncies are riddled with problems, especially breaking 2nd while power shifting. I have gears (3.91's), but I don't do the highway thing. I just drive local roads. I have, however, heard alot of good things from the Tremac series. Alot of friends still use them for drag racing. I am trying to stay old-school.
  5. outlawjose
    outlawjose Member
    USA
    2 dr Maverick
    2.75's are a little compiclated around town. I'd say you may want 3.00's or (if you can find them 3.25's. I run a wide ratio, but looking to swap to a close, even a gearset if I can find one reasonable.
  6. Shorty
    Shorty Member
    Lafayette, In
    I'm gathering the last remaining parts I need to swap my C4 for a top loader 4 speed and 4.11:1 9" into mine. I've had this trans and rear end since my first Maverick in '79.
    Bruce
  7. tody
    tody Member
    cologne, germany
    i am building my 347 for low end torque to compensate for that. i had a close ratio too, but chose the wide for better driveability instead.
  8. rthomas771
    I tried a 3.00 in my Falcon which is a lot lighter than a Maverick and wouldn't pull from a dead stop without riding the clutch. This was with a T-10 that has a 2.36 first gear compared to the 2.32 in the close ratio Toploader. I now have a close ratio Toploader and 3.25 gear but I still gotta pedal the clutch a time or two to get my roll quietly rolling on flat ground and this is with 24.5” tires. I miss my 3.70 but not on the hwy screaming 4000 just to keep from getting ran over in the slow lane.
  9. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I had the stock 2.70 gears in my Maverick when I first swapped the Toploader into it. I didn't have a problem at all.
  10. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Being on a budget, I was actually considering one of the overdrive Toploaders (three speed, with 4th overdrive) for my Mav with the 4:11 rear gears.
    I've heard the 3+1 Toploaders aren't as strong as the standard 4-speed TL's, but my engine's going to be mild performance, '71 302, Thumper cam, headers and a 4-barrel.
    The 3+1 should satisfy my stick-shift cravings 'til I can afford a Toploader 4-speed (with a switch to 3:00 or 3:25 gears out back) or a T-5 swap with the 4:11's
    (note: My car's a 69.5, so tranny tunnel room is a deciding factor)
  11. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I had a 70 Torino GT with a 4 speed and 3.00's and didn't have any trouble around town with it. That thing would cruise down the hi-way though. The pic of you r tach reminds me of my GTO, 4.10's, 3500 TCI convertor and a 455. It would screeeeem at hi-way speeds.
  12. outlawjose
    outlawjose Member
    USA
    2 dr Maverick
    3+1 TL is a good choice, and you can still have decent highway. The only drawback is the step between gears, which can make around town a little difficult. My uncle's 66 Mustang had a 3+1 in it, he used 3.55 gears to balance out the driveability factor.
    The reason for my choice is sheer "muscle car" factor. This is my second Mav with 4 speed and I really like it. Banging through the gears is fun for the whole family.
    My current Mav is a 70. It has been difficult to get the proper fitment of the linkage to the trans. I actually had to modify the tunnel to accomidate the shifter rail for the 3/4 link. It seems the floors are a little different on the later ones. My other car went right in with tons of clearance.
    The current car I don't plan on drag racing. I may, if I feel like it, but road racing seems much more challenging. I've also found that there are parts that deem it easier to make it "road" ready with little difficulty.
  13. spork1o1
    spork1o1 Member
    Michigan
    I need to get my 5.0/289 hi-bred on the dino. I am running a wide ratio top loader and have no problem getting the Mav. rolling from a stop, with 1st or 2nd gear running the stock 2.79 gears out back. At 80mph im running 3000rpm.
  14. Tenebros
    Tenebros Member
    Indiana
    1969.5 Maverick
    I want a 6 speed... :drive:
  15. rthomas771
    Wide ratio Toploaders has a 2.78 1st gear. The cam size has a lot to do with choosing rear gear ratio also.
