4 speed automatic
Discussion in 'Technical' started by OLD GOOSE, Oct 5, 2011.
  1. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Has anyone put a 4 speed automatic in a Maverick? if they have what problems did you have and what clearance issues are there other than the usual transmission cross member driveshaft etc..
  2. mojo
    Do a search! There have been several 4 sp autos by those on the forum. I believe "71Gold" makes crossmembers for the swap. Frank has pretty much had every conceivable combo u cud imagine in his Mav's.
  3. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Did a search did not see anything
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If you didn't already search using the keyword AOD
  5. 71gold
    there are at least 41 on here...that's how many AOD crossmembers I've sold...:Handshake
  6. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    wow ton of info looks to be too much of a hassle for what i will use the car for ,think I'll stick with my c-4
  7. Resto
    Resto Benders Evil Twin
    Yuma AZ
    How much would 1 cost to 85365?
  8. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Its not too hard since all the research has been done already. Just need to get the right flexplate, 28 or 50 oz., block plate, trans itself, Lokar T.V. cable, and a crossmember. Bolt in the blockplate, flexplate, then trans. If you get franks mount then that bolts up too. run the T.V. cable from carb to transmission. then hookup up whatever kind of shift linkage you are going to use. the tricky parts are setting the correct T.V. line pressure, and pulling the headers away from the transmission pan if you have long tubes.
    Let me add that if you are runnign stock gears then the AOD will not be a good choice. It will bring your cruise rpm down too low. If you are running 3.50 gears and up then it would be a good mod.
  9. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Thanks for the info i read 411 is probably the best gears ,is that correct?
  10. Ryan
    Ryan Ford Addict
    Phoenix Az.
    4.11 are a bit much for a street car and would still bring your 60mph cruise up to about 3000 Im guessing. I have 3.89 gears in my 9 inch and I was cruising about 2500rpm at 60. But if you are just going around town and no long freeway cruises the 4.11 would get you off the line quick and have a nice cruise on surface streets.
  11. 71gold
    my 3:55s at 70 was...2200 RPM.
  12. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    I don't have the correct speedometer gear in my AOD. At approximately 60mph the rpm's are 2100, with 4.11 gears.
  13. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I dont have the right gear either. Its all just a guess on speed. When I was thinking about getting the right gear all I could figure out was a gear for 3.73 and for 4.11. there was no right gear for 3.89.
  14. mavgrab302
    If I kill my c4 the AOD swap is what I will do....
  15. PaulS
    Yes, the 4.11 gears are perfect and should have your cruise rpm between 2000 and 2500 depending on tire size.
    Paul
