390?
Discussion in 'Technical' started by 71mavkidd, May 19, 2009.
  1. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    I have access to a 390 for cheap and found a thread where it does fit, however i do not know what transmissions will go well or what kind of power i will be looking at. I also understand that my 71 straight six will need a suspension upgrade, but i am not really sure what this will consist of.
    thank you for your help.
  2. rayzorsharp
    I think you better do some more reading. This will be a major undertaking!
  3. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Yup, definate undertaking.
    So much that I had a built 390 and C6 already ready to go, could have pulled from one vehicle to another, but I didn't do it. To much work
    Shock towers are in the way, C6 wont fit in the tranny tunnell without lots of mods, etc.
    Youd be better off with a small block of some sort
  4. TUK101
    TUK101 Member
    Elk WA
    72 Maverick 4dr/302 V8, 1963 Ford Custom 500 inline 6
    Yes, a 390 is a pretty wide engine. Plus it is longer to boot. Also a C6, which you better be running behind a 390 is a long, large around tranny. Not to mention that the bell housing in itself is a pretty large chunk of metal.
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    as much as i love my 390 highboy, not worth the effort in a driver mav.
  6. baddad457
    390's a great motor, just not in a Maverick, unless you plan on converting to a Mustang II front suspension.
  7. PaulS
    You can always run a C4 behind the 390. If they hold up behind a 429 and 460 it will be ok behind the 390.
  8. Andysutt
    Conway Arkansas
    1972 Comet GT
    Do they make an adapter to run a c4?
  9. sierra grabber
    northern nevada
    I know you can get an "AOD" adapter for the FE big blocks. that would probably be a better deal for the effort.
  10. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Performance Automatic sells a bellhousing for FE to C4
  11. Andysutt
    Conway Arkansas
    1972 Comet GT
    Cool thanks. I hadnt kept up with FE stuff in the last year or so
