351w plugs keep sutting
Discussion in 'Other Automotive Tech & Talk' started by JHodges, Sep 25, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I decided to get dads tr7 with a 351w out today and get it running again. The engine is basically stock other than an aluminum intake 600 holley vc carb and shorty headers. I thought the black sut was from a weak ignition. I put my msd blaster 2 coil, a new duraspark module, cap and rotary button on it. I also put a new set of plugs in it. I cranked it up and it ran real crappy. It had covered the plugs in black sut in about 10 minutes. I had this carb on my maverick and it did the same thing. It is an electric choke carb and I have the choke adjusted so the butterfly in it is straight up and down. I am thinking it may be jetted way to rich but not sure. Any help or ideas is appreciated
  2. mean_maverick
    yeah, sounds like it's running way too rich. i agree with you, i'd start with the jets and while you have it off it might not hurt to throw a kit in it :huh:
  3. Mavman72
    May also have a ruptured power valve...this will cause a rich condition as well.You are definitely getting too much fuel.
  4. tim keck
    sharps chapel,Tn
    X2, check it first. Holleys are bad to blow the power valve, all it takes is one good backfire.
  5. Joe Dirt
    x3 sometime even a little cough will do it
