347stroker or 302
Discussion in 'Technical' started by J_dub, Dec 30, 2005.
  1. J_dub
    J_dub Member
    Paducah KY
    1970 Maverick Grabber
    what is the easiest way to distinguish a 347 stroker from a regular 302
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Pull it apart;)
  3. Mavaholic
    Its all internal but if you pull the pan you will see where the block is notched out for rod bolt clearance on the 347.
  4. RabidCustoms
    or you could look at the machinist bill, and parts invoices:D
  5. J_dub
    J_dub Member
    Paducah KY
    do you have a picture of what the nothing would look like or maybe a link to a picture somewhere that would show exactly what this would look like.thanks.
  6. J_dub
    J_dub Member
    Paducah KY
    notching not nothing oops
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    Just look for notches in the bottom of the cylinder bores that line up with the rod bolts. It would not be possible to distiguish the two from the outside.
  8. bmcdaniel
  9. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Couldn't one pull a plug, rest a 'measuring stick' on top of the piston, turn the crank and measure the stroke? (3.0" vs 3.4" ?)
  10. Acornridgeman
    Wisconsin
    That is great thinking, but I don't know if you could get the right angle on a wedge head spark plug hole to get a small dowel to the bottom of the stroke - now if it was a hemi head !!:clap:
  11. Rick Book
    Rick Book Member
    Thailand
    Doh! I didn't know about that.
    Thx
  12. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Probably the best way to tell would be to drive it.
  13. Rick Book
    Rick Book Member
    Thailand
    ha! The most obvious of all!
    ....unless the car isn't driveable or the engine is on the floor of somebody's garage.
  14. bmcdaniel
    Nascar measures displacement using a big graduated container of jelly-like stuff. They squeeze it into a spark plug hole with the piston at TDC and see how much the combustion chamber holds, then they put the piston at BDC and see how much volume it takes the fill the cylinder. Mutiply that figure by the number of cylinders.
  15. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I think I would expect to see all sorts of invoices and reciepts.
    Even with papers, it would still be hard to tell if the work was done right.
    Someone cannot expect a premium in price if they cannot prove what they say.
    Otherwise, they may just be looking for a sucker.
    Dave
