28oz vs. 50oz
Discussion in 'Technical' started by Jay Johnson, Dec 29, 2015.
  1. Jay Johnson
    Jay Johnson Member
    Hawaii
    I am about to buy a flywheel to install when i do my T5 install. Which one should i get and what is the advantage or disadvantage?? will i, should i match the harmonic balancer to the flywheel? not sure whats on there now.... 71, 302....
  2. mojo
    71 engine ....28oz damper
  3. Jay Johnson
    Jay Johnson Member
    Hawaii
    so i guess i should be looking for a 28oz flywheel then correct???
  4. Powerband
    Powerband Member
    NY's \H/
    to be clear, the Flywheel probably weighs @ 20 lbs, the external balance weight is 28 oz.
    have fun
  5. Mavman72
    Yes...you want a 28oz imbalance fly wheel for a 71 302.
  6. Powerband
    Powerband Member
    NY's \H/
    Are all the Maverick's 157tooth/28 oz or are 164 T FW's used?.
    thanks
  7. dyent
    dyent Member
    vancouver bc
    to the best of my knowledge, Mav/Comets with 302's only came with 157T flywheels, use of 164T required a different bellhousing which had a slight bulge at the top for clearance, plus starter location was different too for the larger 164T flywheel. 10" and 10.5" clutch/pressure plates could be used with 157T and larger 11" with the 164T.
    David
