164t bellhousing
Discussion in 'Technical' started by jean282, May 30, 2010.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    Anyone use the 164t bellhousing (from mustang) i have one and i want to use it whit a 50oz motor but i dont know which flywheel will work. I have read on other forum that one from 87+ f150 will work but i want to know if someone can confirm this. thank you
  2. don graham
    I'm assuming you are talking about a bellhousing for a c4 tranny. The bellhousings are the same for the c4's. Either the flexplate is a 157 tooth or a 164 tooth. The model of car is not a factor. Only wether it is the right size bellhousing.
  3. 71gold
    the...crank balance...decides the damper weight...(28 oz/50 oz)
    the...crank balance...decides the flexplate weight...(28 oz/50 oz)
    the...flexplate...(157/164)...decides the bellhousing...(large/small)
    the...bellhousing...(large/small)...decides the flexplate...(157/164).
    ...:Handshake...
  4. mean_maverick
    nice breakdown Frank :thumbs2:
  5. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    i have a bellhousing for a manual transmission. I decoded the number on my bellhousing and i have a 164t but i dont find any flywheel listed 164t 50oz only 164t 28oz.
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Probably have to get an aftermarket flywheel to get it 164 t and 50 oz weight....
